BlasterKX Posted March 15, 2009 Report Posted March 15, 2009 Welll heres what it does while normal riding its fine. but when your going up a hill or thru somedeep soft sand you get a jerking almost jumoing teeth feeling. my chain slack is exact i did notice my rear sprocket teeth arent great but it was doing it before i put this sprocket on. so im at a lose and im hoping someone can help me out. thanks fellas Quote
BansheeRider87 Posted March 15, 2009 Report Posted March 15, 2009 Is your swingarm bearing good? Mine were bad and made it skip teeth every now and then from the flex Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 its jumping teeth on the sprocket. it either needs tightened or you need a new sprocket. check your carrier bearings. they may be worn out.. Quote
BlasterKX Posted March 15, 2009 Author Report Posted March 15, 2009 i had brand new sprockets on it before but it had to much slack gearing then was 13/41 i figured the slack in the chain was causing it. so i went and got a blaster rear sprocket(40) and took a link out and now its 13/40 with perfect chain slack but then my buddy today told me my sprocket was about shot i look down and was like damn. half my teethe where half way gone.lol. an das far as my carrier bearings go i think there good but il double check them reason why i say that is because this is a different carrier then before also cuz the top bolt hole was all walood(sp) out and i got a better one and a bigger bolt for the new one and it still does it. so im clue less. Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 its simple man. your chain is skipping teeth. it probably just needs to be tighter. if your chain was loose before, why didnt you just tighten it? i dont understand why you put a new sprocket on it just because it was loose. you have chain adjusters for that. Quote
BlasterKX Posted March 15, 2009 Author Report Posted March 15, 2009 sorry bout that. meant to say it was to loose and had to take a link out because with the carrier all the way slid back it still had alot of slack in it like way to much. and as of now when i sit on it it tightens up to be perfect. when im not sitting on it it has like 2 fingers of up and down movment. im getting another 40 tooth tonight so im hoping it will fix it Quote
BlasterKX Posted March 15, 2009 Author Report Posted March 15, 2009 (edited) yea its weird but its the only way to fit my 13 front properly. idk since the chain is streched out a lil bit from riding on a new chain i might try and fit a 41 back on the rear and see what that does. i hope i can figure this out. i dont think it would be anything internal would it? maybe possibly my tires and or tires size? Edited March 15, 2009 by BlasterKX Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 nope, sounds like youre just jumping teeth. tighten it up a little more and see what happens. Quote
BlasterKX Posted March 15, 2009 Author Report Posted March 15, 2009 ok il see what that does for it. i just dont want to have it to tight. thanks again and il let yuo all know what it does after i tighten it up Quote
