blaster2006 Posted February 23, 2009 Report Posted February 23, 2009 heya, i need your opinions if i should get an adjustable timing plate and set it to +4, but i would like to know if its easy to install, cause if i get it my mechanic will be installing it.. but he has never really put a timing plate so hes also unsure of exactly how to put it on, will i need a flywheel puller and would i need to remove my flywheel? or its an easy bolt on and form there i turn it about and mess with it to get the +4 timing? i also read somewhere you need like some kind of spacer like a business card or something like that it seems tricky but if anyone can tell me how easy it is to install and what i have to do after removing the stator cover how do i install it fully. thanks Quote
DallasGDub Posted February 23, 2009 Report Posted February 23, 2009 http://www.bansheehq.com/forums/index.php?showtopic=96721 Quote
official_style Posted February 23, 2009 Report Posted February 23, 2009 its really easy to slap on. i bought the chariot one, you will need a flyheel puller and blue loctite. put it on yourself, it doesnt take long, i used a magazine cover to set the gap. Quote
