Question for you guys, I stood my banshee up on its ass end to clean underneath. Is it normal for the gear oil to leak out of banshees when you do that? I'm guessing it's coming out of a vent.
hey , welcome to the BHQ!!! and yes there is a vent at the back of the engine case.probably the source of your leak.
Thanks man. So are just not supposed to stand them up on there ass end then?
you can, but youre gonna get that shit leaking out of there. its not gonna hurt anything unless you lose a ton of oil.
There should be a hose that goes on the vent. The hose should be routed up twards the front end. That way when you stand it up oil wont run out.
josh
right on i'll check maybe I forgot to hook that up when I put the motor back in thanks dude!
It should come to a T where the back vent and the vent under the water pump cover come together and then go up twards the steering stem under the fuel tank
