Banshee-Predator_Owner Posted February 1, 2009 Report Posted February 1, 2009 Im looking for 2 replacement sleeves, my pistons wore uncentered and ate the sleeves out egg shaped Quote
sheerider1026 Posted February 1, 2009 Report Posted February 1, 2009 can they not be bored?? its usually better to find a good set of used cylinders Quote
Wildcardracing Posted February 1, 2009 Report Posted February 1, 2009 I would recommend just buying some good used cylinders. They usually run no more than $250 for an unported set. You will be looking at least that much per cylinder to have them resleeved. Plus resleeved cylinders choke the transfers even worse making them harder to extract the horsepower. Quote
KEVSWS6 Posted February 1, 2009 Report Posted February 1, 2009 I have an unported set of stock cylinders with Wiseco pistons. Only a couple hours them. They are at 64.50mm Bolt on and ready to go. $250.00 shipped to you. Quote
