Face Posted January 19, 2009 Report Posted January 19, 2009 I want to get a clutch cover insert plate, but I want to know what it involves to take the old one out and install the new one. Do I just need to drain the oil? Also the water pump cover. I know its a newbe question but help me out! Thanks in advance! Quote
bansheejoel Posted January 19, 2009 Report Posted January 19, 2009 I want to get a clutch cover insert plate, but I want to know what it involves to take the old one out and install the new one. Do I just need to drain the oil? Also the water pump cover. I know its a newbe question but help me out! Thanks in advance! its prolly the easiest thing you will ever do. Just take out the 3 screws, pop out the plastic one and the o-ring thing thats on it and pop in your new bling. Put the new screws in and your all set. Doesnt get any easier than that bro Quote
KaosBanshee44 Posted January 19, 2009 Report Posted January 19, 2009 Same thing goes for the water pump cover just three screws and put the new one on there is no oil draining involved. I would put a little just a little blue thread lock on the screws they tend to vibrate off and then your having to find replacement screws. Quote
FASTOYS Posted January 19, 2009 Report Posted January 19, 2009 Here is one to look at, as you can see there is only 3 screws to hold it on with no oil or anything behind it : http://www.farmandsandtoys.com/partdetail.asp?partid=48 As stated above, very easy to do, 3 screws and your done. Quote
