R/C Hippie Posted January 16, 2009 Report Posted January 16, 2009 Just a thought you mite want to look at the chariot performance reeds they are ceeper and clam more hp I just got a set and they look nice havent used them yet thow. Quote
flint Posted January 16, 2009 Author Report Posted January 16, 2009 Just a thought you mite want to look at the chariot performance reeds they are ceeper and clam more hp I just got a set and they look nice havent used them yet thow. i already have the v forces got a good deal on a set barely ran. and same with the 2into1 intake set up. just wondering if anyone has any input on the cascade stuffers thanks josh Quote
Snopczynski Posted January 16, 2009 Report Posted January 16, 2009 i already have the v forces got a good deal on a set barely ran. and same with the 2into1 intake set up. just wondering if anyone has any input on the cascade stuffers thanks josh No, you dont run the stuffers in the vf3 cages on a 2 into 1 intake. You actually have to take a dremel and match port the intake to the reedcage, and grind a buch off the reedcage stuffers. You have to do this to match them up right to the billet intake. Using the vf3 with a 2 into 1 intake is like pulling in two different directions. mid-top reedcage with a low-mid carb setup. Your better off with stock cages and aftermarket reed petals like a low or mid tension carbon tech setup. Quote
flint Posted January 16, 2009 Author Report Posted January 16, 2009 well i also have a set of v force delta 2's and a set of boysen on stock cages. between the 3 what do you guys recomend? Quote
Snopczynski Posted January 16, 2009 Report Posted January 16, 2009 What type of riding do you do with the bike, and what do you want the power delivery to be like? Quote
flint Posted January 17, 2009 Author Report Posted January 17, 2009 (edited) What type of riding do you do with the bike, and what do you want the power delivery to be like? this bike i am building mainly for the track. have a cool head fmf pipes and dynatech ignition. Edited January 17, 2009 by flint Quote
Snopczynski Posted January 17, 2009 Report Posted January 17, 2009 You would have to tell me the reed tension before I would recommend any of them. I recommend a low or mid tension carbon fiber petal on a stock reed cage. Quote
flint Posted January 17, 2009 Author Report Posted January 17, 2009 You would have to tell me the reed tension before I would recommend any of them. I recommend a low or mid tension carbon fiber petal on a stock reed cage. thanks Quote
