klemet banshee Posted January 13, 2009 Report Posted January 13, 2009 hey if someone could school me on what a powervalve achieves and how it works??? Quote
blowit Posted January 13, 2009 Report Posted January 13, 2009 hey if someone could school me on what a powervalve achieves and how it works??? This technology has been beat to death in other threads. Please do a search and you will find all you need to know about power valves. In short, you ride woods and tight, technical stuff, you want it. You drag only, you do not need it. Brandon Quote
trex banshee Posted January 13, 2009 Report Posted January 13, 2009 the powervalve basically adjusts your exhaust duration depending on rpm. at lower the rpms, the powervalve is closed which results in more low end power. As rpms increase the valve opens increasing your top end. Quote
2001Stroker Posted January 13, 2009 Report Posted January 13, 2009 Basically, it will make your 2-stroke pull like a 4-stroke. Your "power band" will be through the entire rpm range. Just to sum it up. Quote
klemet banshee Posted January 13, 2009 Author Report Posted January 13, 2009 how much do these top ends go for?? and do i need to get anything special for it?? difrrent domes pistons?? stuff like that Quote
blaster2006 Posted January 13, 2009 Report Posted January 13, 2009 PM sent on that. ok, sorry to ask on your post but talking about powervalves, do shees have them on the stock cyl? Quote
2001Stroker Posted January 13, 2009 Report Posted January 13, 2009 no. only RZ350, which i'm sure you don't have Quote
klemet banshee Posted January 13, 2009 Author Report Posted January 13, 2009 think anyone would trade for a 94 kx 125 :biggrin: Quote
