gsl65 Posted January 3, 2009 Report Posted January 3, 2009 I pulled the head off my Banshee and saw that the head gaskets is blown. Does anyone have suggestion about the type of head gasket to buy or are there any installation tricks? Thanks! Quote
bansheefreak Posted January 3, 2009 Report Posted January 3, 2009 just go to local stealershit tell them you need a head gasket or a topend gaskit kit.. normally brand is cosmetic.. that or time to buy a noss head and bump up your compression with domes... Quote
firebanshee Posted January 3, 2009 Report Posted January 3, 2009 I pulled the head off my Banshee and saw that the head gaskets is blown. Does anyone have suggestion about the type of head gasket to buy or are there any installation tricks? Thanks! I like to put that copper coat sealer on the stock head gasket before i put it on. Or just put a coolhead on :biggrin: Quote
Darthwall Posted January 4, 2009 Report Posted January 4, 2009 just follow the manuel and everything should be good stock head 20-25Lbs should be good on the studs if you want to spend more on gas get a cool head! Quote
bansheefreak Posted January 4, 2009 Report Posted January 4, 2009 just follow the manuel and everything should be good stock head 20-25Lbs should be good on the studs if you want to spend more on gas get a cool head! if he gets a cool head he will not spend more on gas unless he gets race domes.. you can still run pmp gas and bump up compression for lil more low end feel without paying more for gas.. Quote
