So when the bike warms, while riding it starts to break up and sputter.
The guy workin on it, is trouble shoooting it right now. Its not a jetting issue.
Now it will barely start, could this be coil, stator, cdi???
thanks
Sounds like the cdi box. But i would change the spark plug caps first i had a problem kinda like that and i changed them and it worked. Plus spark plug caps are alot cheaper.
What he said. :biggrin:
I swapped the cdi, I dont think its that.. New spark plug caps and then swapped coil.
I have a inconsistant spark. Sometimes is strong sometimes weak..
Yes it is the stock stator.
I've always understood that electrical problems tend to show up when the bike is warm. So you're on the right track. Ohm the stator and check back in.
