pdbanshee Posted November 29, 2008 Report Posted November 29, 2008 almost done with a bottom and top rebuild putting everthing back together put my cards on and the left one its bowl in to close to the clutch push lever and ideas how to mix or where i went wrong the push lever is all the way down and seated really hard to hold the clutch in thanks for any help Quote
pdbanshee Posted November 29, 2008 Author Report Posted November 29, 2008 no still stock carbs that was going to be my next thing to do Quote
RUDEDAWG Posted November 29, 2008 Report Posted November 29, 2008 Does the left carb wiggle when you pull in the clutch lever? Is the carb rubbing against the bottom of the carb? Just trying to figure it out. Quote
pdbanshee Posted November 29, 2008 Author Report Posted November 29, 2008 Does the left carb wiggle when you pull in the clutch lever? Is the carb rubbing against the bottom of the carb? Just trying to figure it out. yeah it wiggles bad its sitting right on top of the lever i thought when i put the air box back in it might light the carb up a little but it didnt help Quote
fastrthnu Posted November 29, 2008 Report Posted November 29, 2008 then the lever is prob not seated all the way. take you preasure plate off and pull the pushrod out a bit and see if it drops down more. the part the cable hooks into should be level with the center of where the tip of the cable mount/clamp down in the middle of the case is. Quote
pdbanshee Posted November 29, 2008 Author Report Posted November 29, 2008 then the lever is prob not seated all the way. take you preasure plate off and pull the pushrod out a bit and see if it drops down more. the part the cable hooks into should be level with the center of where the tip of the cable mount/clamp down in the middle of the case is. ok ill double check and ill get back to yeah probly tomarrow thanks for the help Quote
RUDEDAWG Posted November 29, 2008 Report Posted November 29, 2008 yeah it wiggles bad its sitting right on top of the lever i thought when i put the air box back in it might light the carb up a little but it didnt help You didn't by chance put the actuator lever in backwards did you? look at the pics above, that is the direction the arm should face. Quote
pdbanshee Posted November 29, 2008 Author Report Posted November 29, 2008 You didn't by chance put the actuator lever in backwards did you? look at the pics above, that is the direction the arm should face. no its in right with the way the indention on the arm is i dont think u could put it in backwards put it is faceing the right way Quote
RUDEDAWG Posted November 29, 2008 Report Posted November 29, 2008 Well, if the clutch actually disengages then I have no clue cause if it werent in all the way I would think that it wouldnt even move the push rod. The clymers manual says to put the actuator arm in before you put the push rod in. Hope this helps. I am no expert. Quote
pdbanshee Posted November 29, 2008 Author Report Posted November 29, 2008 Well, if the clutch actually disengages then I have no clue cause if it werent in all the way I would think that it wouldnt even move the push rod. The clymers manual says to put the actuator arm in before you put the push rod in. Hope this helps. I am no expert. ill go back over everything in the morning got to work tonight thanks again Quote
pdbanshee Posted November 30, 2008 Author Report Posted November 30, 2008 hey i worked it out losened it up some and bent down a hair works fine thanks for the help Quote
2001Stroker Posted November 30, 2008 Report Posted November 30, 2008 Boss racing intake solves that problem. It moves the left carb up and back a little. I have one, and have plenty of room between the carb and clutch. Quote
