bad ass camaro Posted November 8, 2008 Report Posted November 8, 2008 does enyone know if its ok to stand a yfz up on the rear tires to transport it? I was told that oil will drain into the air box, it so whats the trick . Quote
Paddleboy Posted November 8, 2008 Report Posted November 8, 2008 well i put my shee in the bed of my truck so that all 4 wheels are flat on the bed. but i supposed you could use a trailer too Quote
MarineNYC Posted November 8, 2008 Report Posted November 8, 2008 well i put my shee in the bed of my truck so that all 4 wheels are flat on the bed. but i supposed you could use a trailer too WTF are you talking about? How in any way does your reply have anything to do with his question? Quote
2001Stroker Posted November 8, 2008 Report Posted November 8, 2008 This must be the guy that had a fourwheeler strapped to the roll-up door on a U-Haul. Quote
JasonsBanshee Posted November 8, 2008 Report Posted November 8, 2008 Don't quote me on in but I believe all you have to do is shut your fuel off and you'll be fine. I see guys stand both 2 and 4 strokes up all the time. I say go for it bro! Quote
2001Stroker Posted November 9, 2008 Report Posted November 9, 2008 If you're worried about the oil draining into the air box, drain the fluids before you transport. Don't forget to put the oil back in when you get there. Quote
fox_forma Posted November 9, 2008 Report Posted November 9, 2008 stand it up on the grab bar on the street and see if it drains into the air box or not. If it does find a solution, if not load it up Quote
shee rips Posted November 9, 2008 Report Posted November 9, 2008 i dont see why it would. the cylinder sits farther forward than most of the bottom end, so the oil should go to the low point. only one way to know for sure tho Quote
2001Stroker Posted November 9, 2008 Report Posted November 9, 2008 I forgot to mention earlier, gas is very likely to come out of the carb overflow. Quote
spike Posted November 9, 2008 Report Posted November 9, 2008 We've done this many times with my buddy's. and it depends on the bike... The Honda would loose oil but the Suzuki kept it, I'm not sure about the YFZ but i think the crankcase breather tube goes into the airbox and its where oil comes from. One solution could be to xtend the tube and re-route it so it goes to an higher point on the bike. here's our redneck setup :biggrin: Quote
05.Banshee.SE Posted November 9, 2008 Report Posted November 9, 2008 WTF are you talking about? How in any way does your reply have anything to do with his question? Lmaooooo. I don't know if it's myth or not, but from all my years of riding, standing a bike up is a no no with all those fluids flowing in odd places. Throw it in the bed of your truck...or on a trailer... I really want an enclosed trailer actually. Quote
Paddleboy Posted November 9, 2008 Report Posted November 9, 2008 yea i was just joking around but i guess it just flew right over some of ya. Quote
