Like Dajog said, and you may need some taller adjusters.
I would also recommend you check your boost bottle for leaks/air leaks. :confused:
yep i tried and tried and i cant get em to go any higher with the stock (keihin) adjusters. the cable is a new motion pro. looks like ill have to find or make some taller ones.
yeah the pro design intakes arent worth a shit.. it has leaked on me before thats why it is siliconed up to the max in that pic...
i have a boss intake on my other engine and it is the bomb. i am fixin to get one to replace this busted ass pro design.
thanks for your help fellas, mark
I have a set of the PWK33's and the slide goes ALL the way up out of view!!
In fact, that is how I sync my carbs...
All the way open at the lip is a point I can repeat on both carbs for perfect balance. :thumbsup:
I'm sure no one will disagree with me on the sync thing........uh~huh.
