hi guys,
im new here and i have a little issue with my banshee
i recently changed the headgasket because i was blowing a ton of white smoke out of one exhaust...
that went smoothly and i went to start it up again and it ran but when i gave it full throttle it booged way down.. it felt like it only went 1/4 of the way up to full throttle..
its cold outside since i last rode it and thought that was the issue so i rode it and it took full throttle and riding the clutch to go maybe 10 mph
any thoughts or ideas would be greatly appreciated
~Glen
Edited by garyh58
Welcome to the HQ...I would first make sure all the head boltsa are nice and tight lke they should be. The white smoke may not have been a head gasket and could have been another issue altogether unless you did find the gasket messed up. Also use the search feature(if you havben't already) and you may find more than you are looking for and could find the exact fix you are looking for..
the gasket was covering what it was sopposed to... and no i didnt remove the carbs but air fuel screw are both out 2.5 turns
mabey there's coolant trapped in your exhaust. what all did you take apart/ change? check plug boots and wires
did you take anything else off besides the head?
lol do u mean the shee bogs when hitting the throttle and doens't rev either in 1/4 throttle or Wide open throttle.
lol if yes then the parking brake where is the clutch need to be lubricated. it may get sticky by sand or other etc... u just have to make sure when you are hitting or releasing the clutch the parking brake won't move with it and it should be completly shut.
:cool:
In other words the TORS if you still have the stock carbs check all the wiring going to the carbs.
And get you a clymers manual when you get a chance, you'll need it. BTW......Welcome!
well i got it all fixed.. the gas tank was sitting wrong due to a short fuel hose so it was hitting the throttle cable... anyways its all good thanks for all the replies:)
anybody know about the 400ex big bore strokers?
some guy wants to trade even think its a good deal or are those motors junk.. i heard the cylinder walls are very weak
No way, its a good motor but no way compares to a banshee with or with out a motor.
Oh crap....it's always the little, not serious stuff that always gets you....I got out to the dunes one day and my wife's bike wouldn't start....I checked everythig multiple times....Aftrer about 20minutes I realized a buddy came over and turned the gas on....I had turned the gas on and she had came behind me and turned it off when I wasn't looking..
I had the same thing happen. My buddy shut off the fuel when we were transporting it, and I didn't know that, cause I never do (it's never enclosed, and I don't haul it to far).
It took me a while to get it running, lol. :down:
