skinindustries Posted October 27, 2008 Report Posted October 27, 2008 I am lookin for 2 gears 1 is the primary drive gear if that is what you call it it is the gear that goes on the crank shaft that is ran by the clutch and the other gear is the water pump impeller gear that junk plastic one haha if anyone knows where I can find these parts that would be awesome these are the only parts I need then my rebuild will be done and I can finally ride ha thanks for the time Quote
