acfine Posted October 24, 2008 Report Posted October 24, 2008 (edited) Hello All, Before: FMF Fatty Exhaust w/ CoreII silencers K&N Filter K&N PowerLid 260 Mains 25 Pilot Needle 3rd Clip After: NOSS Coolhead w/ 21cc Domes - Added FMF Fatty Exhaust w/ CoreII silencers K&N Filter K&N PowerLid Boyesen Carbon Fiber Dual Stage Reeds - Added 300 Mains - Added 25 Pilot Needle 3rd Clip And also changed from a twist throttle to thumb throttle and put new throttle cable in. Before the mods, it ran like a bat out of hell, now I have no low end. Should I start with changing to the fourth clip on the needle, or going to 27.5 pilot jets. Also, since the new head and domes, just above idle, it has a distinct "new" popping noise, and doesn't feel as strong in the power band. And one more thing, it smokes like a freight train. I run 50:1 ratio... Any thoughts or advice are much appreciated, Anthony Edited October 24, 2008 by acfine Quote
acfine Posted October 24, 2008 Author Report Posted October 24, 2008 I just pulled the plugs, and the left side, where the choke is, that spark plug is wet and oily, and that pipe has a ton of oil coming out of it, the other side, the plug was dry, and not as much oil coming from that pipe. What does that tell me? Thanks, Anthony Quote
acfine Posted October 24, 2008 Author Report Posted October 24, 2008 i just swapped the plugs, and the thing screams again! But the side of the motor the choke is on, pops, but only that side. What does that mean? Thanks, Anthony Quote
vulvafan537240 Posted October 27, 2008 Report Posted October 27, 2008 did you sync the carbs when you put the new throttle cable on? Quote
2001Stroker Posted October 27, 2008 Report Posted October 27, 2008 did you sync the carbs when you put the new throttle cable on? x2. Quote
Snopczynski Posted October 28, 2008 Report Posted October 28, 2008 Choke balance tube on? Torn intake boot on the right side? Quote
acfine Posted October 29, 2008 Author Report Posted October 29, 2008 It's weird, I was out Satyrday riding, and it'd definately an elecrical problem. While accelerating, it would go in and out of full power intermentently. Could the TORS have something to do with this? Sometimes at startup, if I try and rev it, it acts like the parking brake is set, just bogs badly, and then I just wiggle the wires going into the clutch perch, and it starts reving like normal. Thanks Quote
snoxrage Posted October 29, 2008 Report Posted October 29, 2008 It's weird, I was out Satyrday riding, and it'd definately an elecrical problem. While accelerating, it would go in and out of full power intermentently. Could the TORS have something to do with this? Sometimes at startup, if I try and rev it, it acts like the parking brake is set, just bogs badly, and then I just wiggle the wires going into the clutch perch, and it starts reving like normal. Thanks i had the popping problem..did tors removal and rebuilt the carbs..Runs awsome! Quote
Snopczynski Posted October 29, 2008 Report Posted October 29, 2008 Sometimes at startup, if I try and rev it, it acts like the parking brake is set, just bogs badly, and then I just wiggle the wires going into the clutch perch, and it starts reving like normal. Thanks Dont you think you answered your own question with this comment? You have to fix known issues before you can diagnose a problem that may be associated with what your worried about. Quote
05.Banshee.SE Posted October 29, 2008 Report Posted October 29, 2008 It's weird, I was out Satyrday riding, and it'd definately an elecrical problem. While accelerating, it would go in and out of full power intermentently. Could the TORS have something to do with this? Sometimes at startup, if I try and rev it, it acts like the parking brake is set, just bogs badly, and then I just wiggle the wires going into the clutch perch, and it starts reving like normal. Thanks Remove the TORS, then clean the carbs. Quote
tundish2800 Posted October 29, 2008 Report Posted October 29, 2008 Get rid of the tors and the parking brake all together that should help i had the same problem on one of my old shees Quote
