Paddleboy Posted September 23, 2008 Report Posted September 23, 2008 is the gain of a 4 mill with porting worth the money or should i just stay with porting and something like a coolhead. funds are low since i bought my house so i'm thinking instead of getting my shee ported this spring of just saving up the extra money and going for a 4 mill and porting to save money in the future when i want it faster. also what exactly is needed to get a 4 mill on a piped shee useing stock cylinders. thanks Quote
elwilliams13 Posted September 23, 2008 Report Posted September 23, 2008 You need the long rod stroker crank, 795 pistons, either spacer plate with stock head or stroker domes with a coolhead type everything else can stay the same. I just built one and had it ported agressive trail and it runs with the YFZ450 all day. I also have some suspension work done and it helps to keep the power to the ground. It is about a 7% increase in all around HP with more bottom end than a stock stroke. If you can wait till you got the cash and do it all for the best effect. Quote
Paddleboy Posted September 23, 2008 Author Report Posted September 23, 2008 thanks.. but with the 4 mill and port you should be able to whip those 450's. i got pipes and hang with them Quote
pr0blumz Posted September 23, 2008 Report Posted September 23, 2008 is the gain of a 4 mill with porting worth the money or should i just stay with porting and something like a coolhead. funds are low since i bought my house so i'm thinking instead of getting my shee ported this spring of just saving up the extra money and going for a 4 mill and porting to save money in the future when i want it faster. also what exactly is needed to get a 4 mill on a piped shee useing stock cylinders. thanks You don't need a spacer plate. You can have your stock head modified. I went from stock to a HJR 4mil so I can't comment on the difference between it and only stock stroke ported cylinders. I was told the 4mil would give me a much broader powerband over just ported cylinder. I still use my stock carbs and 3 HD clutch springs. Give Kevin @ HJR a call and he can put you on the right path. Quote
Wildcardracing Posted September 24, 2008 Report Posted September 24, 2008 thanks.. but with the 4 mill and port you should be able to whip those 450's. i got pipes and hang with them I believe he meant with bottom end power. His engine is set up for awesome low end grunt. You have several options with the 4mil: Short rod with your current pistons and a spacer plate or cut domes/rechambered head Long rod wth 795series pistons and a spacer plate or cut domes/rechambered head And all of the same porting types avaialable for the stock stroke. Added hp accross the board and a more broad usable power band. Plus if you do the chambered head or stroker domes...who has to know?? Quote
Paddleboy Posted September 24, 2008 Author Report Posted September 24, 2008 thanks alot guys. i think i'm going to start saving some cash to throw in the pit. Quote
