i had her out couple days ago and worked great and then didnt put her in the garage and it rained and now it wont idle unless im keep on the gas. and it will drop a cylinder and kills would this be the coil and the rain had nothing to do with it. i have a lot of mods and she ran great until it rained. please help
Are the Carbs syned close?
the right side is set.... did you look at the window to the left side? They both have to be in the window at the same time, or pretty close.
I changed it to a single carb 5 years ago have a lot better power when i did and is easier to tune
you mentioned it rained pull your stator cover to see if you got moiture in it. If thats ok then you might want to check electrical connections for water in them. you also could try to readjust your idle mixture maybe the weather is affecting that much.
stator dry check connections will try carb setting
