rad95banshee
Everything posted by rad95banshee
  1. Do you have either set of carbs left? Sent from my VS985 4G using Tapatalk
  2. So I need a new stator should I buy a good used oem or should I give the race tech a try? Anybody have any experience with the race tech stators?
  3. I had problems with mine starting till I set the gap on the pickup.
  4. About 5,000ft elevation
  5. Ok so I just dropped the main jet down to 110 and it sounds 100x better.
  6. Currently running one 35mm pwk 202main 50pilot needle is two clips down from the top running pro circuit platinum 304 silencers
  7. So I just rebuilt my top end. Big bore kit 68mm pistons. I was running a pwk 35mm 2into1 but it seems to be starving for fuel now. I jetted up to a 202 from a 162 main made a little difference but still doesn't have that snap when you hit the throttle. What would the best setup to run on my configuration? 68mm pistons, mild port job, pro circuit pipes, vforce4 reeds. Mostly trail riding. Any advice is much appreciated! Thanks!!!
