Geisick
Everything posted by Geisick
  1. Selling a complete custom 16mm banshee engine. It has nothing but top of the line parts to make the most powerful and reliable combination possible. The entire engine is practically brand new as it was built with all new parts, crank, rods, clutch, pistons, bearings, seals etc… this last spring. It was dyno tuned and ridden one time last year, thus why I am putting it up for sale. 16mm billet Crankworks crank that has light weigh crank webs and is completely dynamically balanced to the weight of the pistons, then trued, and welded. 78mm Cheetah DM cylinders that are completely ported, and port matched with the cases, and comes with all the reeds, intakes, head o-rings, with two sets of custom cut domes (have two sets depending on elevation and fuel) Matton Billet Banshee cases ported, trenched and setup for the DM cylinders with the correct studs. Billet transmission gears that are fully micro polished and undercut. (undercut grears essentially will allow you to shift as fast as an override, but can also be ridden like a stock tranny without ruining the tranny or bending shift forks) Complete Hinson Billet Clutch setup: billet basket with springs (instead of cushions to hold up to the power), billet hub and billet pressure plate which allows for running and extra fiber. Direct Drive lockup clutch kit Direct Drive one piece reinforced clutch cover Direct Drive roller for pressure plate Straight cut gears Kick starter steel idler bushing Timing plate There is other stuff I can’t think of right now, and as stated you can see everything has been built with top end parts for strength and durability. There is also a lot of custom pieces and too many details to list. It is a great engine, but haven’t had enough time and have too many other projects. Selling this engine for half of what it would cost to duplicate. $7950 outright, or will knock $1000 off for a good banshee engine as a core. Best way to reach me is call 970-768-7168 (leave message if I don’t answer) or email me at [email protected]
