GONE1445
    2005 bone stock for now...
GONE1445's Achievements
  1. How much wider can you go with a tire and not have problems mounting it on a rim I'm looking at getting some itp holeshot xcr's that are 20x11-9 and i wanted to mount them on some bead lock rims that are 9x8 are the tires too wide? Wheels are hipers btw Same for the fronts 21x7-10 and rims are 10x5 Also the front offset is 3.0+2.0 And the rear offset is 3.5+4.5 will this give me a bit wider stance over stock?
  2. ok so I decided to go for the deal elka has going on for the stage 3 suspension for the banshee, but when I was ordering it on the phone they wanted my SS# since they are shipping from Canada to the USA this obviously threw up a red flag as I know you don't just hand out your ss# has anyone else ran into this problem and is there a way around it? I thought maybe buying it through a 3rd party like lone star would work?
  3. I recently picked up a 2005 yamaha banshee, my first two stroke that I've ever owned, I'm working on getting it setup the way I want it for the woods its 100% stock right now I already plan to drop down a tooth on the front sprocket and I was thinking about getting some fmf gnarly pipes to move the power down lower in the rpm range I dont want to run turbine core or power core scilencers because I live in michigan and the sound limit here is 94db instead of the normal 96, usually they will let 96 slide tho also I gotta have a spark arrestor so I was wondering how well the gnarlys will work with stock scilencers or are the Q's worth the money? I dont see them really being that much better than stock but maybe someone can enlighten me
