Hey guys. I installed the tors removal kit yesterday on my 03 banshee. While i had everything apart, i changed my stock jets to 260's which i recived with my fmf fatty pipes. got the carbs back in, synced them and then attempted to fire up. it didnt wanna go so i put a squirt of fuel in carbs and it then fired. once it fired up it seemed very laggy on the bottom end, seemed like it only wanted to stay running if i was 1/2-full throttle. Then all of the sudden it stopped firing on one side ( could only see exhaust smoke on one side). i can get it to fire now without squirting some gas in the carbs, but it needs to be choked. Everything ran fine before the tors kit was on, with the exception of a little lag in the bottom end sometimes. Air screws are 1.5 turns out, choke hose is connected between carbs, electrical connections are good. going to grab some new plugs on the way home incase its as simple as a fouled plug. Does anyone have any other suggestions as to wh its only firing on one side, and why it quits when i attempt to idle it? Thanks guys!!
