martin (arg)
Everything posted by martin (arg)
  1. ) What type of aftermarket exhaust do you have? PRO CIRCUIT 304 PLATINUM 2) What type of airfilter do you have? PRO FLOW PRO DESIGN 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all AIRBOX WITHOUT LID 4) What is your elevation? SEA LEVEL 5) What size pilot jets are you using? 27,5 6) Needle Setting? STOCK ON 5TH POSITION 7) What size main jets are you using? 290 8) What temperature is your Banshee jetted for? 20 °C 9) Do you have a port job? NO 10) What kind of carbs? STOCK 11) Reed Valves? STOCK 12) What type of fuel are you using) 97 PREMIUM 13) What gas/oil ratio you use? I LITER GAS / 250 CC OIL 14) What type of premix you usE? MÁXIMA CASTOR 927 15) Timing Adjustments? DYNA FS CUSTOM MAP ON +4 DEGREES 16) Boost Bottle? MOOSE 17) Spark plugs? NGK BR8ES
