banshee1911
Everything posted by banshee1911
  1. i have a 371 banshee with 34 mikuni carbs what do i need to no what main and pilot jet to use
  2. i have a 371 banshee with 34 mikuni carbs what do i need to no what main and pilot jet to use
  3. i have a 371 banshee with 34 mikuni carbs what do i need to no what main and pilot jet to use
  4. i have a 371 banshee with 34 mikuni carbs what do i need to no what main and pilot jet to use
  5. I have a 371 banshee with vm34cc round slide carbs my problem I don't have a clue what to jet it Main jets or pilots
  6. I have a motor that was told would be a 421cc motor. When i looked at it when i got home things did't look right so i took it apart and found out i had a stock crank new brgs.115mm rod with a blaster 0.100 over piston. What i ended up with was. stock crank and new brgs. 115mm rod blaster piston 0.100 over Clyinders ported drag port. not what i wanted 371cc motor not what i wanted what i ordered was a 4mill motor but the builder talked me into a 4mill with a blaster piston you end up with is a 421cc motor. I have 34mm carbs I don't have a idea of what to start with main jet or the pilot jet CAN ANYBODY HELP ME!!!!!!!!!!!!!!!
