94Mike
Everything posted by 94Mike
  1. Down to meet you guys, Or any HQ'er for that matter.
  2. Oh i see, nice.
  3. Nice, where do you normally camp at?
  4. So far im going first time in the sand with the banshee.
  5. Maybe the online won't be BS as in mw2 . Until everybody figured out the "Cheap" set-ups it was fun.. Or the chopper gunner bs....
  6. 94Mike
    J's vs A's
    I see, thanks guys. I have always wanted to look for an 87 because of the originality.
  7. 94Mike
    J's vs A's
    Hey HQ, What were the benefits of banshees switching over from j arm's to a arm's? Also are their any benefits with j-arms? I know this is more of a suspension question but im asking this in a general sense... EDIT: Before anyone posts that why am i asking... This is just a question.
  8. 94Mike
    Help
    Another thing is.. would you go with Ohlins? Or do you prefer Elkas, etc. Ill start looking into another set, single rate or dual rates?
  9. 94Mike
    Help
    Thanks Matt, could you give me a rough estimate on what year they are? They are not leaking, but they do squeal (im not sure what causes that) They seem pretty good still (im no expert in the shock department though)
  10. 94Mike
    Help
    Thanks Matt, looking forward to the response.
  11. 94Mike
    Help
    Im not familair with shocks but are they a run of the mill aftermarket single rates or are they pretty good single rates. Also how would you compare Ohlins to Works or Elkas? Are they pretty good to stay with or eventually will i want to go with dual rates i plan on getting a 2+1 a arms later on..... or is it all preference........
  12. 94Mike
    Help
    In a good way or bad way lol.
  13. 94Mike
    Help
  14. Are the carbs overflows leaking? I had an issue like yours and it ended up being my float height. But I replaced my fuel valve and the fuel valve seat, but it turns out the floats got messed up as the tips of the pins got mushroomed somehow (i had to beat the pins out) so I got replacement floats.
  15. Lol lt500 are beasts, Are they always hard to start?
  16. 94Mike
    Help
    Ok are these any better, also what would it cost to have the shock rebuilt, springs painted, and also is it possible for the body to be painted? Left Right
  17. 94Mike
    Help
    Thanks Matt, Like i said ill throw some better pics in the morning. The only one i had and it is a crappy pic...
  18. 94Mike
    Help
    Hey HQ, I have a set of ohlins for the front but im not sure which ones they are, if somebody could help me that would be great. Also if they are a decent shock or better. Ohlins Sorry for the dirty quad. Ill post better pictures in the morning. Thanks, Mike On the rezzy it says Ohlins Gas Shock Sweden
  19. Lol I like that newspaper under your banshee in your sig.
  20. Hey Chuy ever go to Dumont once in a while?
  21. Sound better then T5's? Wow maybe i will get a set, Will they work good with a stock stroke/bore/unported cylinders? I later plan on going with the Serval...
  22. Lol Phelps Anyways i would check the obvious, For carb syncing you can sync them by eye (so the slides pull at the same time) but you can get a sync tool that shows the vacuum on each carb and you can sync the idle too.
  23. Thanks NYUK, It isnt too bad unless i climb a hill or hit a bad bump. But i guess it is worth the time and the fix then to keep adding oil and wasting money on oil.
