vs7
Everything posted by vs7
  1. Where is the best place I can buy Sand Skate II online? I searched the net but cant fined it
  2. Where is the best place I can buy Sand Skate II online? I searched the net but cant fined it
  3. No, I never drove it in this modification Everything was stock and I installed all those modification at once. Now I’m in the process of jetting and I don’t want to mess things up
  4. I really appreciate your advice, let’s see other members comments
  5. Hi, I have these parts installed on my new 2009 Banshee 1. Stage IV Exhaust System 2. Adjustable Timing Plate (adjusted on 4°) 3. Cool HEAD 4. DOME 66MM-20CC-12 5. K&N AIR FILTER BANSHEE 26mm No Box 6. NGK Iridium Sparkplug BR8EIX 8. V-Force 3 Reed Valve Everything else is stock The temperature I s between (50-85) F and the altitude is between Sea level and 2000 Ft Max 27.5 pilots jets and 300 Main is this combination right and do I need to play with the needle clip Please I Need your feedback ASAP.
  6. and what pilot jet to use
  7. up
  8. Any other opinions
  9. So you recommend a 320 because my mechanic recommends 280 and trinity recommends 290
  10. Why
  11. Hi, I have these parts installed on my new 2009 Banshee from Trinity Racing 1. Stage IV Exhaust System 2. Adjustable Timing Plate (adjusted on 4°) 3. Stage IV Standard Head BANSHEE BILLET STAGE IV HEAD 4. STAGE IV DOME 66MM-20CC-12 5. K&N AIR FILTER BANSHEE 26mm 6. Yamaha Banshee Reed Spacers 7. NGK Iridium Sparkplug BR8EIX 8. V-Force 3 Reed Valve Everything else is stock Now here are my question What should the number on the jets be? I rely appreciate your inputs and advises
  12. Thanks Man for the info evry thing with a stage name is from Trinity Racing
  13. Thanks Im @ sea level
  14. I rely appreciate your reply and your time spent replying My elv is sea level and sometimes it reaches 700 miters @ places I visit
  15. Hi, I have these parts installed on my new 2009 Banshee 1. Stage IV Exhaust System 2. Adjustable Timing Plate (adjusted on 4°) 3. Stage IV Standard Head BANSHEE BILLET STAGE IV HEAD 4. STAGE IV DOME 66MM-20CC-12 5. K&N AIR FILTER BANSHEE 26mm 6. Yamaha Banshee Reed Spacers 7. NGK Iridium Sparkplug BR8EIX 8. V-Force 3 Reed Valve Everything else is stock Now here are my questions 1. What is the level of compression and how much should the level of octane be? 2. How much horsepower should these parts add? 3. What should the ratio of gas and oil be (using yamalube)? 4. What should the number on the jets be? 5. What else can I do to gain more horsepower? I rely appreciate your inputs and advises
  16. Hi, I have these parts installed on my new 2009 Banshee 1. Stage IV Exhaust System 2. Adjustable Timing Plate (adjusted on 4°) 3. Stage IV Standard Head BANSHEE BILLET STAGE IV HEAD 4. STAGE IV DOME 66MM-20CC-12 5. K&N AIR FILTER BANSHEE 26mm 6. Yamaha Banshee Reed Spacers 7. NGK Iridium Sparkplug BR8EIX 8. V-Force 3 Reed Valve Everything else is stock Now here are my questions 1. What is the level of compression and how much should the level of octane be? 2. How much horsepower should these parts add? 3. What should the ratio of gas and oil be (using yamalube)? 4. What should the number on the jets be? 5. What else can I do to gain more horsepower? I rely appreciate your inputs and advises
