Shee274
Everything posted by Shee274
  1. no i didnt... i was hopin i could work around that with the air screws but what would you recomend??
  2. Need help got my banshee out of storade and i elimated the air box and put 2 pod filters on when riding it i cant run full throttle but still hav a strong powerband until i hit 5th gear and while ridding i noticed white smoke then no smoke then white smoke i also adjusted the air screwsan no luck... also banshee is completly stock to thanks!!
  3. Hey once again needing some help i lost the instructions on how to install the pro armor kill switch an im pretty lost... any advice would be much apprecitaed and was in napa today and found a set of truck lite 12V LED lights that look just like the lights from banshee expect LED and allumin wondering what does the stator put out and if it would work before i spend 100 bucks on them thanks!
  4. okay well it did come with extra set of rims and tires and i changed the bent rim out and with another rim and tire and it still has a slight shake at top end coming from the rear tire so i im guessing thats its etiher a bent axle or spindle...... anyone know of a good axle? and why so much hate on the ricky stator i was always told that that was top of the line
  5. Hey bought a 2003 banshee Limited edition the other day for 1300. I bought on a whim that i could possible make some money in the future on it compeletly stock except for front rims and ricky stator stator. the bads is that i will need to strip the frame and get it either painted or powered coated including the arms and it has a bent rear rim. it was sitting for two years and its still on original rebuild.
