99navyta
Everything posted by 99navyta
  1. Thanks Ill give it a try
  2. It doesn't have the silencers on it just the expansion pipes. I'm going to rebuild the carbs and see if it helps. Where is the best place to get a rebuild kit?
  3. I assumed the carbs needed going through because the bike was blown up years ago and sat in a garage since, but I would think it would run for a few seconds by spraying fuel through the carbs.
  4. It has fuel in the tank.. It has New plugs.. Its getting spark.. I just put a brand new .20 wiseco kit in and milled the head so it has plenty of compression.. The only thing I can think is that it came with an adjustable stator & plate installed and I thought it might not be right.. It does the same thing if I switch the plug wires on the cylinders, it will just fire once or twice and then nothing.
  5. I bought a 1997 Banshee that wouldn't start.. It has a new coil new stator (adjustable) Wiseco 20 top end .035 milled head If I pour gas directly in the carbs then it will fire once or twice but will not run.
