banshe88
banshe88's Achievements
  1. just wondering about the air screw then, how many turns should i start at and should i go in more turns or out more turns to make it clear up.
  2. i have a 87 banshee with mild port work done toomey t3 pipes v force 3 reeds borded 4 over 28mm kehin carbs with knn filters(pods) just want to know a good starting point for these carbs. main jet, needle, # of turns for the air screew, and the pilot jet. the carbs have in them right now, 185 main, needle is stamped with a j on it, the pilot is a 58 n the air screw is 2 turns out. the quad runs perfect until i put into gear, just bogs right out n then nothing. played a little around n moved the the clip on the needle, n just need a better opion for these carbs.
