jmorando05
Everything posted by jmorando05
  1. Where are you located? Im looking at the plastics and the nerfs.
  2. I just switched plugs and wires and the same cylinder always fires and the other kicks in at high rpms and slightly at low rpms. checked the plug after wot run on the one not fully firing and was wet so it is getting fuel. would this be a jetting issue or possibly reed issue?
  3. it cranks but wont fire it has no idle screws i just ordered them. only time it will run (like shit) is if i jump it.
  4. yea i just ohmed it out and the pickup coil was adjusted so its perfect and now i have constant spark but it still wont fire. going to try new gas and see if that helps but now im really stuck. it has the tors eliminated without the idle screws installed and it used to run fine but would this causethese symptoms? idk where else to look im kind of at a dead end.
  5. just walked out fucking around thought i would kick my balls off it starts first kick. idled fine once warm. ripped it up the rd and when i hit 4th it went then died and wouldnt start back up again.. its either gotta be a lose ground or maybe the jetting?
  6. fmf pipes. the weather has changed i live in the northeast and its now in the 70's but it was working since the temp went up. i started it up ran it cleared it out then changed the plugs and nothing so tried another set of new ones and nothing. finally went back to the original ones that were in there working and again nothing.
  7. i tried that already. actually twice.
  8. So it wont fire at all and its getting minimum spark. The tors is disconnected to the throttle and the carbs and when plugged into the tors box i get no spark and when i disconnect the connector it wwill start only when jumped by being pulled from another quad. When it does start it runs but its "hectic" it sounds feels like one cylinder is firing and then as i hit teh throttle and get to higher rpms the other cylinder kicks in. Any ideas? the tors was disconnected when i got it and it ran fine and then all of the sudden a month later this is what i got. James
  9. where in new york ill take the blue plastics..
