Wideopenthrottle
Wideopenthrottle's Achievements
  1. Did you sell the cool head yet
  2. Just wondering if you had a chance to ship it thanks
  3. I tried to leave you pm yesterday. I want it send me your paypal info . I also asked if the cable comes with it.
  4. Just wondering if you still have it I am interested let me know
  5. I let it idle for about 2 minutes before I ride to warm up and I let it run out of gas. Then pull the plugs I will be pulling my carbs off again to see if I have more trash if I do it could be trash in the tank . Hope it works I'll be doing a plug chop tommorow.
  6. Yep I did I use castor 32 to1 . I pulled the plugs today and put new ones they were black and wet. But what confuses me is that after I put the new plugs it still did it then I pulled the choke out and it stoped but I thought when your plug was black and wet it was to rich so why when I pull the choke it runs fine? I'm so dam confused
  7. I will be rejetting soon, the gas is only two weeks old I ran out went to the gas station and filled it up I put it in the day before I left and rode it a little bit not sure how fast it would seperate. I had the carbs out day before yesterday and apart they were a little dirty so I thought it might have been that so I cleaned them, same thing happen. The tors is unpluged but I will soon get an tors eleminator. What size jets do you think I should use not to familiar. And I'm thinking of junking the boost bottle what's do you all think. Thanks again for the help.
  8. I have a 2004 banshee it has toomey t6 pipes and jets, 2 into 1 t6 air filter and boost bottle. I rode the bike two weeks ago and it ran fine then I left to go to works for two weeks offshore. When i got back home and started it it started fine went for a ride after it warmed up and at about half throttle it spit and sputtered through all gears. Thought it might have been compression but did a compression test and it was at 120psi on both sides. It is a little colder here than it was before I went to work does that mess with a banshee alot. I am new to 2 strokes not to sure. Temp is usually 75 to 80 in Louisiana and its about 40 now. Also took carbs apart and they are very clean. If anyone has any idea I appreciate the help thanks.
  9. How much for the 28mm mikuni flatslides
  10. I have a 2004 banshee with toomey 6s might be willing to trade. I work offshore will be able to send pics in a few days when I get home if your interested. The frame is the same color as yours with white plastics and trim is same color as frame. I live in Louisiana . Let me know thanks.
