David DeLeon
Everything posted by David DeLeon
  1. Bump
  2. Not on the wrong forum, TRX protrax swingarm will not fit a banshee protrax. I know this for a fact. The TRX uses an off set shock mount and the pivots are different. The Leagers uses a factory banshee bolt and banshee round carrier. The protrax also has the wrong track for the chain, the sprockets do not line up. Still need a Protrax Banshee Swingarm or anyone who can make one up.
  3. bump still need one
  4. Still looking for a swing arm to fit a Leagers Protrax Banshee frame with CR500 link
  5. Have both, $80.00 shipped
  6. I have a good one $75. shipped
  7. I might have one, I will check my stuff tonight when I get home. Have to check condition. Send you reply later. David
  8. Not sure were you are at but there is a guy who has one for sale for $700 on craigs list riverside ca area, see link below http://inlandempire.craigslist.org/for/2727926596.html David
  9. I am not sure which toomey;s they are, but I believe they are T3 or T4 they are not T5s. If you want a picture send me your email address and I will shoot you a picture of them
  10. The laeger frame is far better. It uses 250R front angle suspension, with T-spindles, which make it very easy to turn no matter how much pressure is on the front end. No bind on anywere on the suspension as they do not use ball joints. The rear shock is out of a CR500 modified works shock and can give you any were between 11 - 13 inches of travel. This quad was designed by Marc Laeger and is today even one of the best set up ever. I have one that I built in 95 and yes it is pricey but well worth it. Won lot of races with it. Very hard to find one used, no one will let thiers go. New frame from Scott at Laegers is around $8500. Comes with steering stem, a arms, spindles, tie rods, rear swign arm. Power coated. Few items you will need, will be CR500 link off a 91 or newer CR500. Bearing carrier included with swing arm. David DeLeon
  11. Good used set of black toomey pipes for sale. Pipes only no mufflers. $100.00 plus shipping
  12. I have a good used banshee seat, with desert foam and blue seat cover. $100. plus shipping
  13. I have one from a 93 thats why I was asking. If you want it sell it for $50 plus shipping
  14. What year there are two different ones
  15. I will not seperate them. I am selling as a complete kit. Sorry
  16. I have two banshees and both are set up very similar set up. Stock cylinders, aftermarket reeds, FMF Gold Series pipes, stock air box with snorkle removed. I run 290 Jets. Carbs are sync correctly. They have TORS removed. Aftermarket idle screws set up. I can not get the motor to idle. If I adjust the throttle cable it will idle, but I can not get it to idle without tightening the cables. The idle screws are all the way in. I have checked the small jet and it is clear. Should I put a larger idle jet in? Or am I missing something. Thanks in advance. David
  17. I realize this is an old post, but I have a Leagers Protrax Banshee, what are you looking for?
  18. I have a frame from an 88 Banshee. Frame and title only $200.00 California Title
  19. I have a good used stage IV two into one manifold, carb, filter and throttle for sale. Complete ready to install. $180.00 Plus shipping. I do use pay pal if needed. Located in souther Calif Email me for pictures. David [email protected]
  20. I use half links all the time, since the early 90s The problem is they are not available for oring chains. You can only get them for non oring chain. I have a Laegers frame banshee and a 93 stock frame. I have half links in both. I think its the gearing you are running. I ran 15 / 40 for years and ran into the adjustment issue. Replace the chain with non oring and install the half link.
  21. I bought a Laegers frame back in 95. Mark Laeger built mine long before he sold out. My banshee was built using all of the banshee components. You do need different shocks which are very expensive. You will need to use brakes from a like 93 model. The rear uses a round housing with the factory caliper. I raced it D38 and in Tecate Mexico. I have one overall in 97 with it. Very stable and fast. I had this in storage in 2001 had some items stolen. Engine and rear end were stolen. I have recently rebuilt it and getting ready to take it out in 10 days. If you want to know more about it, email me [email protected] David
  22. Did you ever sell the swing arm or do you still have it? I am looking for a Laeger swingarm for the banshee protrax frame.
  23. Still looking for one. Anyone out there know were one might be? HELP
  24. looking for a swing arm for a Leagers Protrax banshee. It uses a CR500 Link. Please help anyone have one out there?
