Ok any help will be appreciated.
I bought my 99' banshee about three years ago. It has always run great, then it slowly started getting harder to start and would just flood. I could pull start it and once warm it would start fine.
Recently while riding the the throttle started sticking and if i shifted into a higer gear and popped the clutch it would stop and then run fine again. I was about to park it and the throttle then stuck at about 3/4 throttle, pulling the teather, shutting off the key, and switching the handle bar switch off did not kill the bike. After about 15sec it died on it's own. I waited a hour and it started back up but i did not drive it. This scared me so i decided that i have been riding it for a few years without doing any work on it except for plugs, and oil.
I decided to rebuild the carbs not knowing what the problem was. It will now, without flooding, start fine with the choke full on. However it idles pretty high, and idles up and down on its own. If i push the choke back in it will die. Also while trying to get it to idle correctly it once again went to 3/4 throttle on it's own, and shutting off the key, switch, and pulling the teather did not kill it. After about 15sec again it died and will start back up but i'm lost on what to do.
I have been reading around and have heard about air leaks, TORS problems, Reed problems, and sticky throttle cables?
Anyone who can help me please write me back ASAP. If any additonal info would be helpful let me know.
THANKS,
NICK
