4milstrkr
Everything posted by 4milstrkr
  1. The last time I put a new top end in my banshee was in march of 2009. It is stroked 4mill, bored .40 over slight port job, cool head with 18cc domes. I haved noticed a loss of power and my compression has droped to 160 psi. and it still has the spacer plate under the cylinders. My big question is what whould i replace if i rebuild it and will removing the spacer plate and have a set of cut domes thrown in will I notice a difference. The crank was put in summer of 2008, how long do the bearings last on a hotrods 4mill crank
  2. i really noticed it after i put the 18cc domes in the bike, im runing 114 octane fuel, stock carbs with a 340 main, 800ft elevation. and the porting i did myself just narrowed the bridges and smothed all the rough edges
  3. filter is clean what could cause a bad spark, i am also having to shrink my plug gaps
  4. plugs look good, about 170psi
  5. i have a 96 banshee, procircuit exhaust, ported, 4millcrank, 18cc domes, nology profire coil, bored .40 over, rad valve, rmstator ignition, my bike has a bad high end miss in 5th and 6th gear. it pulls harder at 1/4 throttle in 6th gear than at full throttle, and the jetting is perfect what could it be????????
  6. do i need procircuit specific o-rings for my procircuit exhaust?
  7. i want a good high quality twist throttle and cable currenty have motion pro turbo throttle and cable but the thing just has to much slop, have adjusted many times and cant get it right
  8. i have a 96shee, procircut exhaust, toomey clamp-on uni filter, bored .40 0ver, +5 timing, 4millstroker, mildly ported cylinders, prodesign coolhead with 18cc domes, nology profire coil, and aftermarket cdi. but i still have stock reeds and was wondering if the vf'3 would be worth the 230 price tag?
  9. thanks for the tip mine are also numbered 1-1 and 1-2, i looked in the clymer manual but it didnt say anything about it
  10. i am currently rejetting my carbs for the winter temps, and i was just wondering if there is a difference between the left and right carb bowls on stock carburators
  11. what kind of carbs and what size
  12. i use it for recreational riding and i do race flat track with it i have the timing at +4 and just 93 octane for gas
  13. i currently have pro circuit pipes k&n air filter adjustable timing plate 4mill stroker cylinders have been bored ,40 over and have been cleaned up, and a cool head with 22cc domes stock carbs with jet kit i dont know what else to get any help would be nice
  14. 310 mains stock needles and pilots took stock pilots and needles out to see if would make it run better and it didnt i just rode it lastnight and the left side pipe only fires every now and then until u go above 1/4 throttle and my elevation is 600ft stock carbs
  15. i have pro circuit pipes now im runing 93 octane and psi is 135 both cylinders
  16. stock pipes and yes i did rejet but i put the stock pilots back in because it would run even worse but carbs are syncronized and the reeds looked fine when i rebuilt the motor this summer and it doesnt have an air leak anywhere ive already sprayed it down
  17. i have a 96 banshee it has a 4 mill stroker bored .40 over cylinders have been cleaned up mith a die grinder coolhead 21cc domes procircuit exhaust jet kit and k&n airfilter tors are removed. ever since i put the exhaust on it runs horrible on bottom but srceams when its in the band and only the right side pipe get hot when it idles, it also hardly ever starts and usually needs a pull i have been threw the carbs many times making sure a jet isnt plugged and havent found one, and help would be nice
