ok there are two locations on the inside of the carbs. I have a hose connecting the two larger hoses. Do I need to do the same to the small holes or should something else go there?
Ok I cant get my quad to fire up, it has spark and fuel. I removed the carbs and there was fuel in the reed cage boot. Not sure how to adjust the carbs. I have .30 over pistons and toomey t6 pipes. I am running stock pilots and 280 mains. I see there are two adjustment screws on the carbs. Which one controls which and where about do they need to be? Also I have tors removed and I am unsure if it matters which slide goes right and left. If so how do I tell the difference. Thanks in advance for your help guys!!
Slides are in the correct carb, no tors on the bike and no tors box, new air filter, etc. Not sure about the air screws. I will check that Thanks for all the replies guys
All those are correct so far. Is there somewhere I need to adjust to make them run better?
Crossover tube is good and attached, Bowls are free and clear, Slides moves all the way up and down equally on both sides, carbs have been taken apart and cleaned very well
Haha i put the slide in reverse so it was hitting halfway down and ran crazy haha. Yea I was dumb Now I have another prob. I posted a new subject on it
Not too many mods on the bike. Bored 30 over, magnum crank, stock polished carbs, toomey t6 pipes, v2 reeds, etc
280 mains and stock pilots. We usually run stock pilots here w no probs
Ok guys got my quad running finally. When I start it up it wont start with choke on or anything. The only way I can get it to start is by opening the throttle all the way. Does anyone have any ideas on what I can do to resolve this? Sorry if my question is dumb. Not too knowledgable on banshees
Hey guys I installed some polished carbs and i let the twist throttle cable all the way off so the slides would seat. When I kick the bike over the idle skyrockets and I have to kill it immediately. Any idea why it is doing this and where I can adjust it to get the idle back to normal. Thanks in advance!
Josh
What happens if they are hooked up backwards? I looked at the schematics and it looks like the black wire goes closest to the engine and the orange goes towards the front of the quad. Can you verify that? Thanks for helping me out man
I got that far but the problem is my coil is not labeled pos and neg. I wanted to see which one goes where just by someone looking at their own of if they know. Thanks for the reply though
