KX666
Everything posted by KX666
  1. The banshee motor is a low compression motor (even after you mil the head, unless you have a crazy set up) Forged pistons are not needed, They are heavier than cast, Take longer to worm up Expand upon worming shorter life span than cast. But they will hold up to much higher compression than cast I have had good luck with Vertex Pistons, they are ceramic coated. which runs more efficiently and last longer. I milled the head on my banshee and i am running about 10:1 compression (fairly low compared to my other bikes, they have wisco pistons) I found that shaving down the dome on the vertex piston.
  2. Does anyone have a parts list for the swap? What year works best? Its been a wile since the last time i worked on one of these , are the cylinders nikasiled?
  3. Hey, I am new to the site but i was wondering what is all invalved with the RZ head convertion? I was informed that the head could mate to the stock cylenders but that doesnt sound right. Also what performance diferences has anyone seen with this convertion? thanks!
