tedd1
Everything posted by tedd1
  1. Trade for cash?
  2. I have 421 cub, +12 swingarm, 22x11x8 12 pdl extremes, weigh 220, 5 speed trans. I run 300' with 14-41 gears, leave in 2nd. works well for the 300' but 500' would need a 15 up front or 6 spd tranny.
  3. Just pile it all in the trailer. We will put it together up there in the sand!
  4. Did y'all check with Don up at LSPS? He might donate a dyno run, or something?
  5. I would put it together and see what I came up with for head clearance before changing anything else.
  6. Have you already cut the domes for the 10 mil crank?
  7. how thick is your base gasket in these pics? If you are worried about the top ring, run a thicker base gasket or a spacer to get a clearance you are comfortable with it.
  8. Chariot has a very good set up for stock-ish motors.
  9. the night time is the right time this time of year...
  10. Pros= smoother, easier. more positive shifts. Cons= None http://bansheehq.com...121574&view= http://bansheehq.com...120410&view= http://bansheehq.com...topic=126900 I stole this pic from Savage420...
  11. All forward spaced a arms look similar to that...
  12. Yellow wire is lights from mag. You will need a regulator to not blow lights. It is a small square box under the seat with a blue wire.
  13. Question #35 has been edited. Remember guys, I did not write this article, I only copied and pasted it from many (many) years ago. I appreciate any and all input and will edit as needed to reflect that input. If anyone needs help, please post your questions in the the repairs and mods section. Rick
  14. CP Industries
  15. If they are Lectron carbs, call Packard. They will hook you up. If they are any other brand, it is way more complicated than that...
  16. What is your squish? What thickness base gasket?
  17. If I remember correctly, it was about $40 for the small bottle. I been trying to get the next larger size but all the HVAC guys keep those out all the time.
  18. That's the one I got. Had to buy the first bottle. Swap for free after that. Costs me under $10 to swap for full bottle.
  19. I stand corrected.
  20. The difference will be the later models had the TORS switch.
  21. Adjust throttle to open only half way. There is a stop screw on the back of the thumb housing.
  22. How many of them guys you think will make LS this year? Will we have to kidnap anyone?
