Kilroy
Everything posted by Kilroy
  1. Fixed the problem! A dumb oversight on my part :/ When I reassembled the bike I forgot to reinstall the choke crossover tube. I cut a piece of fuel tubing, put it in place and the bike kicked over and began to idle and hit on both cylinders like it should. Also, one of the spark plug boot ends was a bit loose so I trimmed up the wires and tightened the boot ends back in place. Thanks for the input guys. Kilroy
  2. I'm having the same problems mentioned by ghostryder. We were trying to troubleshoot the problem tonight and we did switch the wires from one plug to the other and this resulted in the left side firing improperly. Initially the right side exhaust is cool and firing improperly; switch the plug wires and the left side mimics the same problems the right side exhaust/cylinder was having. We were thinking it might be bad coil, but I can pull the plugs and check the spark and either plug and they both look bright blue and fire with every kick. Any suggestions are appreciated. Thanks
  3. Yeah, I knew I forgot something :/ The bike has FMF pipes.
  4. Hey guys, I just finished putting a 97 Banshee together and need some advice on jetting. The engine has been bored 1mm oversize while using a stock head that has been shaved .040. Also, using a boost bottle with stock intake and Boyesen carbon fiber reeds. The area I live in is about 210 ft. above sea level. Air filters are dual K&N. If anymore info is needed let me know please. Thanks
