00tbanshee
Everything posted by 00tbanshee
  1. seeing a pic of kevins work when he gets done is always great.let us know how you like it when you get it running.hold on!
  2. trailer jack castor wheel is what its called.get it at a local trailer dealer.it will just slide up into the bottom of your trailer jack
  3. lowbuck,what you running for carbs and head?
  4. they look good lowbuck.also fran i can tell who taught you. :thumbsup:
  5. lol.maybe i'll hit kev up when i come out me and the girlfriend will just stay in it.
  6. kev do you ever sleep?lol
  7. port the stockers will work but i had a set of boyseen rad valve cages couple years ago that was ported.you have to do a good bit of work to them but they worked great with stock carbs but with larger carbs would go with vf3's
  8. if you have a good builder. you can beat the bigger motors with a small motor.lucky me i found one.sure i have been called a cheater more then once.there is some guys out here running bigbore stock cylinders and i think its a waste of money.but now add the tripple port with them and you might be on something.not a bad deal there dave
  9. you hit it on the head.its both
  10. here is where i got mine and no they didn't come with th cushions http://www.motosport.com/offroad/search/in...bCategoryID~272
  11. i run the PE myself on my drag motor and not had a problem.one whole season and no marks from the fingers on the fibers
  12. where the slide goes down you can't get any more the 27.5 cause it will leak air around it.i did a set my self and thats all i could get.as for tapper boring don't think it would help any.as for polishing the carb it would be like polishing the intake in the cylinder.you shouldn't do it
  13. like to see some pics.when will you have your running?
  14. get some pics of the exhaust and the bottom of th transfers
  15. i purge mine at the end of every race at the end of the night.yes i agree alky is the shit
  16. bump for a great price
  17. thanx...
  18. here is the plug and the number on the cdi box is 2GU-51
  19. uncle sam might be sending it, but its really coming from china
  20. agree.i had a junk carb laying around and triied to go larger then that.27.5 is the max. to be safe
  21. my buddy has a aggressive done port with the worm holes and the pistons cut also.he is running cpi inframes and it plan out rips.my motor i ran last yr also has both done to it as well but it was a drag port with shearer out a frames.it was a running too.kev is a great guy and you will like his work
  22. just added couple of you guys feel free to add me.http://www.myspace.com/y2kbanshee
  23. the adj. timing plate is not a bad idea and usually you can find them pretty cheap
