7
Everything posted by Toybreaker
I would but i want my bike back together for the night races at OLDS.
Fleabay for used definitely. Jegs for new Jr dragster slicks. http://www.jegs.com/cgi-bin/ncommerce3/Pro...786&prmenbr=361 http://store.summitracing.com/default.asp?...t=egnsearch.asp but if you are not going to run the strip alot just air your dirt tires down around 2-6 psi depending on track condition and temperature.
MEAT_HEAD had put up a step by step post on how to polish jugs but it isn't in the images forum anymore. I saved it but i can not repost it for some reason. pm me you email and i will email it to you if you want.
Did you guys get your shocks from Flea bay or what? My best friend wants to do the suspension on his Banshee but the cost is kind of prohibitive. Used Yfz shocks just might do the trick. Great pictorial.
hopin to have my shee back together for the 27th. otherwise i will be on my not so trusty LT250R see some of you out there.
Its at Speedworld just outside of phoenix az the week before banshee wars i think. 300ft dragstrip. its all on planetsand.
in a blizzard
already done the shifter star. there is the Packard mod i might do. Anyone here done that mod? Does it help? I have a hard time getting it to shift at wide open throttle.
Those pistons have maybe 6 hours on it. Piston to cylinder clearance is still closer to the low side of the tolerance. thats why i am gonna run a spring hone down the cylinders and replace the rings. Where would i use the yamabond? Same style of stuff as gaskacinch?
I recently took my bike to Glamis and the right rod bearing decided to fail about halfway to Olds. I stopped the engine before it did and real damage to anything else. The cylinders and pistons are fine. The case is undamaged as well. I need to replace the crank. I bought a trued and welded crank. Cylinder base gaskets, Rings, O-Ring kit for the cool head, Clutch cover gasket, Clutch discs, Crank seals, and new reeds(Why not?) Can any of you that have already done this tell me if i have left anything out parts wise? I have a bundle of lint free shop rags and 2 cases of brake cleaner. And any tricks or tips that will make this easier? thanks.
Broken Footpeg Bolt..... what now?
Toybreaker replied to sg30721's topic in Banshee Repairs and Mods
Whenever you are going to use a thread insert style like the helicoil you need to use an STI (standard thread insert) tap otherwise it will not work. It is not a regular m12 tap. it has to be an M10 STI. Go buy the kit it comes with the drill bit, tap and 10 inserts. Usually costs around $45 for a high quality kit. Just like speed parts you get what you pay for. After you get it you can charge your buddies a 6 pack to fix their stuff. Extra inserts are very cheap too. What have any of you guys paid a shop to get repairs like this? Funny thing is even with a broken easy out it is only maybe 30 minutes labor and at most $ 0.45 part. add thread locker to the insert before insertion. -
I jetted my buddies 04 that has t-6's k&n with stock carbs with 320 main and 32.5 pilot. needle 3 from the top. No bog off idle and screams from top to bottom. 1100ft elevation 68F.
If you are any where near San diego i can put a helicoil in it for you. Its easy and would take 10 minutes to do. -
Go to Grainger or some other Industrial supply house and buy the correct Thread repair kit. Use the supplied drill. Drill it oversize. Tap it with the O/S tap and install the thread repair insert. No oversize bolts no hack jobs. no one will even notice it. -
this is links to the apllicable AZ info. might get you on the right track on where to look for your location http://www.ridingarizona.com/forum/topic.asp?TOPIC_ID=15037 and the Arizona Game & Fish site. http://www.gf.state.az.us/pdfs/outdoor_rec...tv_brochure.pdf No Hell has shade and no humidity this time of year
I didn't say there were the better bike all around or a better duner.I also didn't say the 250rs ALWAYs WHOOPED upon gas banshee's either. i just said for stock handling without any aftermarket mods I like the 250R better. And i have seen some REALLY fast 250R's whoop up on some fast bansee's. Now my banshee has A-Arms shocks and soon to have a +4 swingarm. I'll take my banshee over any 250R. Just like my comment about the LT's they handle great. I have 2. Notice my name? Yeah my LT's haven't made a full 4-5 day trip without being put on the trailer early yet. I love the way they handle but they just don't stay together. 87-92 has a crappy chain adjustment method too. Thinking about a LT500CR or LT350Z depends on which i can get done cheaper( I already have a spare top end for a banshee just need the bottom end and exhaust). I have a complete spare LT chassis. Only need motor, exhaust and electronics. Leave it naked and make people wonder.
after it is 5 years old it would have to be emissions tested if you lived in a smog county.
I spend a lot of time at the ISDRA dunes during the cooler months. I disagree with quite a few of you guys. I have seen a ton of modded gas banshee's get spanked by 250R's. However the alky 250R's don't hold a candle to the alky drag banshee's I myself like the way the 250R handles and the powerband 265R that has an agressive port job. For the best of both worlds try getting an R chassis and put in a ported piped Banshee engine. As far as stock handling goes i will go out on a limb and say the 87-91 LT250R handles the best. It is just underpowered stock. Oh can't keep it running either.
Got 2 milled .025 and polished and .060 and polished. Both with water inlets.
Yeah you should see the look on the observers face when you start creaming and it comes out pink! Priceless. Had to go see doc and i HAD to tell him it was a joke or i was gonna get the SWAB. Doc laughed so hard he fell off the chair. That was even better than the look on the Master at arms face when he saw the sample.
The 213 Things Skippy is No Longer Allowed to Do in the U.S. Army SGT Shawn Stanford Once upon a time, there was a SPC Schwarz stationed with the Army in the Balkans. SPC Schwarz was either very clever or very bored; but probably both, since he managed to attempt or be warned about 213 things he wasn't allowed to do. 1. Not allowed to watch Southpark when I'm supposed to be working. 2. My proper military title is 'Specialist Schwarz' not 'Princess Anastasia'. 3. Not allowed to threaten anyone with black magic. 4. Not allowed to challenge anyone's disbelief of black magic by asking for hair. 5. Not allowed to get silicone breast implants. 6. Not allowed to play 'Pulp Fiction' with a suction-cup dart pistol and any officer. 7. Not allowed to add 'In accordance with the prophesy' to the end of answers I give to a question an officer asks me. 8. Not allowed to add pictures of officers I don't like to War Criminal posters. 9. Not allowed to title any product 'Get Over it'. 10. Not allowed to purchase anyone's soul on Government time. 11. Not allowed to join the communist party. 12. Not allowed to join any militia. 13. Not allowed to form any militia. 14. Not allowed out of my office when the president visited Sarajevo. 15. Not allowed to train adopted stray dogs to 'Sic Brass!' 16. Must get a haircut even if it tampers with my 'Sampson like powers'. 17. God may not contradict any of my orders. 18. May no longer perform my now (in)famous 'Barbie Girl Dance' while on duty. 19. May not call any officers immoral, untrustworthy, lying, slime, even if I'm right. 20. Must not taunt the French any more. 21. Must attempt to not antagonize SAS. 22. Must never call an SAS a 'Wanker'. 23. Must never ask anyone who outranks me if they've been smoking crack. 24. Must not tell any officer that I am smarter than they are, especially if it's true. 25. Never confuse a Dutch soldier for a French one. 26. Never tell a German soldier that 'We kicked your ass in World War 2!' 27. Don't tell Princess Di jokes in front of the paras (British Airborne). 28. Don't take the batteries out of the other soldiers alarm clocks (Even if they do hit snooze about forty times). 29. The Irish MPs are not after 'Me frosted lucky charms'. 30. Not allowed to wake an Non-Commissioned Officer by repeatedly banging on the head with a bag of trash. 31. Not allowed to let sock puppets take responsibility for any of my actions. 32. Not allowed to let sock puppets take command of my post. 33. Not allowed to chew gum at formation, unless I brought enough for everybody. 34. (Next day) Not allowed to chew gum at formation even if I *did* bring enough for everybody. 35. Not allowed to sing 'High Speed Dirt' by Megadeth during airborne operations. ('See the earth below/Soon to make a crater/Blue sky, black death, I'm off to meet my maker') 36. Can't have flashbacks to wars I was not in. (The Spanish-American War isn't over). 37. Our medic is called 'Sgt Larwasa', not 'Dr. Feelgood'. 38. Our supply Sgt is 'Sgt Watkins' not 'Sugar Daddy'. 39. Not allowed to ask for the day off due to religious purposes, on the basis that the world is going to end, more than once. 40. I do not have super-powers. 41. 'Keep on Trucking' is *not* a psychological warfare message. 42. Not allowed to attempt to appeal to mankind's baser instincts in recruitment posters. 43. Camouflage body paint is not a uniform. 44. I am not the atheist chaplain. 45. I am not allowed to 'Go to Bragg boulevard and shake daddies little money maker for twenties stuffed into my undies'. 46. I am not authorized to fire officers. 47. I am not a citizen of Texas, and those other, forty-nine, lesser states. 48. I may not use public masturbation as a tool to demonstrate a flaw in a command decision. 49. Not allowed to trade military equipment for 'magic beans'. 50. Not allowed to sell magic beans during duty hours. 51. Not allowed to quote 'Dr Seuss' on military operations. 52. Not allowed to yell 'Take that Cobra' at the rifle range. 53. Not allowed to quote 'Full Metal Jacket ' at the rifle range. 54. 'Napalm sticks to kids' is *not* a motivational phrase. 55. An order to 'Put Kiwi on my boots' does *not* involve fruit. 56. An order to 'Make my Boots black and shiny' does not involve electrical tape. 57. The proper response to a lawful order is not 'Why?' 58. The following words and phrases may not be used in a cadence- Budding sexuality, necrophilia, I hate everyone in this formation and wish they were dead, sexual lubrication, black earth mother, all Marines are latent homosexuals, Tantric yoga, Gotterdammerung, Korean hooker, Eskimo Nell, we've all got jackboots now, slut puppy, or any references to squid. 59. May not make posters depicting the leadership failings of my chain of command. 60. 'The Giant Space Ants' are not at the top of my chain of command. 61. If one soldier has a 2nd Lt bar on his uniform, and I have an E-4 on mine It means he outranks me. It does not mean 'I have been promoted three more times than you'. 62. It is better to beg forgiveness than to ask permission, no longer applies to Specialist Schwarz. 63. Command decisions do *not* need to be ratified by a 2/3 majority. 64. Inflatable novelties do *not* entitle me to BAQ or Separation pay. 65. There are no evil clowns living under my bed. 66. There is no 'Anti-Mime' campaign in Bosnia. 67. I am not the Psychological Warfare Mascot. 68. I may not line my helmet with tin foil to 'Block out the space mind control lasers'. 69. May not pretend to be a facist stormtrooper, while on duty. 70. I am not authorized to prescribe any form of medication. 71. I must not flaunt my deviances in front of my chain of command. 72. May not wear gimp mask while on duty. 73. No military functions are to be performed 'Skyclad'. 74. Woad is not camouflage makeup. 75. May not conduct psychological experiments on my chain of command. 76. "Teddy Bear, Teddy bear, turn around" is *not* a cadence. 77. The MP checkpoint is not an Imperial Stormtrooper roadblock, so I should not tell them "You don't need to see my identification, these are not the droids you are looking for." 78. I may not call block my chain of command. 79. I am neither the king nor queen of cheese. 80. Not allowed to wear a dress to any army functions. 81. May not bring a drag queen to the battalion formal dance. 82. May not form any press gangs. 83. Must not start any SITREP (Situation Report) with "I recently had an experience I just had to write you about...." 84. Must not use military vehicles to 'Squish' things. 85. Not allowed to make any Psychological Warfare products depicting the infamous Ft. Bragg sniper incident. 86. May not challenge anyone in my chain of command to the 'field of honor'. 87. If the thought of something makes me giggle for longer than 15 seconds, I am to assume that I am not allowed to do it. 88. Must not refer to 1st Sgt as 'Mom'. 89. Must not refer to the Commander as 'Dad'. 90. Inflatable sheep do *not* need to be displayed during a room inspection. 91. I am not authorized to initiate Jihad. 92. When asked to give a few words at a military ceremony 'Romper Bomper Stomper Boo' is probably not appropriate. 93. Nerve gas is not funny. 94. Crucifixes do not ward off officers, and I should not test that. 95. I am not in need of a more suitable host body. 96. 'Redneck Zombies' is not a military training aid. 97. Gozer does not dwell in my refrigerator. 98. The proper response to a chemical weapon attack is not 'Tell my chain of command what I really think about them, and then poke holes in their masks.' 99. A smiley face is not used to mark a minefield. 100. Claymore mines are not filled with yummy candy, and it is wrong to tell new soldiers that they are. 101. I am not allowed to mount a bayonet on a crew-served weapon. 102. Rodents are not entitled to burial with full military honors, even if they are "casualties of war". 103. My commander is not old enough to have fought in the civil war, and I should stop implying that he did. 104. Vodka, green food coloring, and a 'Cool Mint' Listerine
Wife - Version 1.0
Toybreaker replied to Rare Scottish Tree Badger's topic in General Banshee Discussion
No about to here. that is some seriously funny stuff. -
Got lowered and lifted stuff at S10forum.com tellin ya check it out.
No kidding with a little 400 and 600 grit wet dry sand paper and plastic renew you won't even be able to tell they were scratched!
I race my LT250R and shee on an asphalt 1/8th mile. Until i ported my banshee my buddies YFZ450 would get a faster E.T. but my FMF piped and jetted Banshee would get a better M.P.H. however my other friends 440ex(totally worked with an edelbrock carb) wasn't even close to my Banshee. Beat him repeatedly by.3 seconds to .7 seconds. Depending on RT. Go to the track and practice a bit before you race him. Get used to the light or starting method where you are going to race. Bet him light for the first couple runs. $50 or so. Sand bag him. . . . Then up it to $300-$500 and waste him. Or race him for pinks.
