03yamahabanshee
    '03 Red black stock first 2 stroke I have ever owned
03yamahabanshee's Achievements
  1. Thanks for the hints. I dont want to sound like an idiot but the first time that it spewed out I was doing donuts in a field and upset it so I added to the bottle and ran it for a while now that will fill the radiator too right? I only filled it to the min line but the second time it did it i was riding a little hard also but i did kinda run a cool down. were is the impeller found and a little off the topic if you were to do some after market changes what would the be and what kinda parts would you use i have herd that i should get a set of after market reeds and mill the heads if i would get a new set of reeds do i have to jet it and when you jet a twin cylinder do you have to have the carbs syncronized and is that hard to do I realize there are a lot of ? so any help you could give me i would really appreciate it. Thanks First banshee
  2. I have had my banshee for about 7 months now and it is the first liquid cooled quad that I have owned. About 2 months ago I was out running it a little hard but not hard enough to overheat, but it did it started spitting antifreeze out from the over flow and has done it several times since any ideas on how to correct the problem or why it is doing it
