bansheeVR4
Contact Methods
  • Website URL
    http://www.spyderracing.com
  • ICQ
    Orlando FL
bansheeVR4's Achievements
  1. Does anybody have the names and numbers any performance shops that can resleeve a banshee by this weekend. It's a 409cc big bore procross kit. I called lasleeve and they have the sleeve in stock that I could get for the person if needed.
  2. HELP ME PLEASE I can't figure this out. My left cylinger is not firing on my shee. I have a procross 409cc big bore kit, toomy T5's and 36mm Kehins. This is what I tried 1. compression Test both Left cylinder (not firing one) 151, Right side one firing 149 2. Brand new spark plugs 3. I tired swithing carbs and cleaning carbs, no change 4. I switched the spark plug wires (nothing) Could it be anything electrical, I just rebuilt the engine...... I can't figure this out helppppp Any Help would be great any suggestions........
  3. Ok I found it I am running 50 pilot jets.
  4. I don't know what size pilots and there is no numbers on them. The air screws are all the way out.
  5. I just moved to FL from CT and I have a 409cc big bore kit with T5's and 34mm pwk's. I run K&N's with no airbox. The left cylinder keeps on fouling the plugs. I took apart the carbs and it has 172 main jets. I am at see level. What do you guys thing the problems is. Jetting or something else.
  6. If anybody can help me out it would be much appriciated. I went out riding the other day and my left cylinder was cutting in and out and then finally didn't work at all. I put new plugs in it and it work fine for about an hour and then the same thing. I tried to reverse the wires for the spark plugs to see if one of the wires was bad but that didn't help at all. I know it's fouling the plugs because I moved the left cylinder plug into the right and vice versa and then the left work and the right didn't. Do you thinks it's the jetting or something else. One other thing is I canged my stator cover to one of those billet ones and when I took off the old cover there was a lot of water in there. Not sure if that could be doing it. The bike has a 409cc big bore kit on it. Kahian 34mm carbs K&N's with no airbox, and Toomey T5's
  7. I used to live in New Milford and there are a good amount of places there are the resoviors but I think they are being built on. Candlewood Lake is sweet during the winter when it is frozen but make sure you have studs or you won't go anywhere. The power lines aren't to bad. I can find out more from my friends but i moved from there to FL about a year ago.
  8. I just moved to florida I have been to ocala a couple of times but let me know when you are heading out. I am always down to do some riding.
