Shee9899 Posted December 5, 2007 Report Share Posted December 5, 2007 installing a set of ten inch itp c series on rear and i was wandering what kind of gearing change it would make and if i would need to go down to a 13 tooth on the front Quote Link to comment Share on other sites More sharing options...
91banshee Posted December 5, 2007 Report Share Posted December 5, 2007 installing a set of ten inch itp c series on rear and i was wandering what kind of gearing change it would make and if i would need to go down to a 13 tooth on the front if your rear tire size stays the same the gearing will be the same , Quote Link to comment Share on other sites More sharing options...
Shee9899 Posted December 6, 2007 Author Report Share Posted December 6, 2007 if your rear tire size stays the same the gearing will be the same , Going from 20-11-9 to a 20-11-10 Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted December 6, 2007 Report Share Posted December 6, 2007 yes 20 is tire hight .. if that stays the same gearing stays the same 11 means tire width and 9 or 10 in your case is rim hight 10-11-12 for tire width fits on your rim Quote Link to comment Share on other sites More sharing options...
serius4play Posted January 9, 2008 Report Share Posted January 9, 2008 ummmm kinda depends on what tiers your runnin are the paddles. if so id that oviusly means u run on the sand so id lower your gearing anyways. unless you have like a stroker moter with alot of power but if its mostly stock id lower the gears if your runnin in the sand of your just runnin nobies id leave it. Quote Link to comment Share on other sites More sharing options...
