36mm kehin jetting help
jason.perez
I’m building a new motor:
t5’s
4mm long rod crank
68mm bore
hjr mx hardcore port w/ case match
vforce 4 reeds
cool head 24cc milled domes   Since I’m trying to run pump gas
and 36mm pwk air strikers
3000ft
was wondering what Jets I need to run just to be in the ball park  Im used to the mikuni jet sizes   The only needles I have  are what is stock in the carbs and also what bp racing supplied me with  Im sure those needles are fine  all the gave me was two differnt main Jets and no pilots (and they call that a jet kit) what Jets should I order  thanks in advance
also, if I Plan to swap out the domes and run race gas would that change my jetting ?
