Engine build advice
Azssminnow
Current mods are:
paul turner mids w fat boys
milled head (not sure how much but it clearly is when I compared it to a factory)
timing plate
vforce reeds (look like older ones)
factory carbs jetted w pods
I ride desert mainly.. if you had say 3-5k to throw at this power wise.. what would you do?
also, any recommendations on who to contact for the build
thanks
Fuel mileage..  not really.  I don’t race.  I just ride around the house because I live in the middle of nowhere.  I imagine I’ll get a high capacity tank if need be..
I assume redline will know what carbs and what not to run with his build.  I just don’t want to be throwing parts at this thing to see what works.  Prefer to just do it right the first time..
I would go with a Serval or low port Driveline set up. Go with a 421. My engine is in the dyno section if you want to look at what that set up can get you hp wise. A builder like Redline or Driveline knows the formula for their engines so they can set you up all the way. Youll need a pro mod transmission and billet clutch basket for the extra power along with the internal mods like high flow impeller, pancake bearing etc.
  • Like 2
Pro mod
Pro mod makes trans stronger?  How would removing every other dog ear be stronger?
