Banshee leak
At first when i pressure tested the engine it leaked at the bottom on the same piece, and i noticed that i was missing a gasket between there, so i put one in on each reed and then tested it, got rid of the leak on the bottom but now there is one on the top of each. How do I feel this and should I worry about it? Thanks. 2200fd3bb2ef3bc1e73b44881d0508e2.jpg
Small amount of yamabond should fix you up, have had luck with added second gasket on both side of cages. Less to clean off later
Sent from my LG-H873 using Tapatalk
Worked good and holds 7 psi for 7 minutes, thank you.
  • Like 1
