Austin 3:16
Banshee Driving me nuts!!
Okay I just rebuilt my engine New crank,New pistons etc. Installed Vforce 4 reeds and timing +4 it also has fmf gold series which where on it before rebuild. Is idling fine and runs fine until it get to a certain spot and just won’t go any faster  it’s no where near as fast as it was. I’ve tried making less and more rich with no change,Gave it more and less air and still no change. Carbs are so clean you could eat off them. I’m at a loss onto what to try. Could I need to rejet my carb because of the reeds or is it something else. Any help is greatly appreciated. Thanks
Share this post
Link to post
27 minutes ago, n2otoofast4u said:
What carbs, what jets?
Stock carbs, 280 Mains,25 pilot. Will add it’s hard to start cold
Share this post
Link to post
18 minutes ago, hoppedupandcutdown said:
Slides in the correct carbs? Bowls on the correct carbs?
Slides don’t have a certain carb they mate with do they? I’m for certain I have them in right in that carb their in thought it only matters if their in right in the carbs.
Share this post
Link to post
I have the bbs or whatever their called lined up for both sight classes and the notches for each idler screw
Share this post
Link to post
Slides are correct then.
Share this post
Link to post
7 minutes ago, gusto said:
Put in a 30 pilot, adjust air screw and report back
Mains and pilots where my next step. Checked the ignition coil and ohm was .9 which I way over the .2-.4 range so possibly is some of my problem also
Share this post
Link to post
Ok
read this,
and next
read this again
After you understand this buy 260-320 mains (if you have the jets great) 27.5-32.5 pilots
Get a longer aftermarket needle set (i like the toomey needles)
I have a similar set up to yours, My bike likes 280 main 27.5 pilot with the needle 2 slots from the tip.
Buy 10 sets of plugs. change jets to your "baseline" and do a plug chop. post pictures of the resulting plug for review (and the inevitable peanut gallery comments)
Share this post
Link to post
5 minutes ago, Toybreaker said:
Ok
read this,
and next
read this again
Okay thanks for the info will let ya know what happens
Share this post
Link to post
7 minutes ago, Toybreaker said:
Ok
read this,
and next
read this again
Beat place to order the pilots?
Share this post
Link to post
Lots of options, use one of the sponsored vendors on the website here.
Share this post
Link to post
Still doing it and also changed coil and moved timing back down
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
