Squish and compression
Deets
I’m impressed with your tool selection. Did you buy that as a kit?
i would recommend you make a template for your porting. Show your exhaust port. I’d like to see how much you’ve hogged out. You can safely remove more at your transfers and intake also, but I like that your playing it conservative.
concentrate on your port angles at the transfers
I Probly only raised exhaust 2 degrees, mostly to smooth out  the port and sleeve transition. I took a good amount out of lowers and definitely the secondary’s to improve entry.
Didn’t buy any of it as a kit, just been adding to it over the years.
  • Like 1
