CarolinaBansheeMan
Banshee project
Just picked this roller up the other day for $400. This is my first banshee so im not sure if this is worth restoring. Its missing some things.
Motor, carbs, tranny, foot pegs, clutch and break levers, thumb throttle, cables, lights, electrical wires, ecu, air box, radiator bolts, gas tank bolts, all the bolts to mount the plastic. If im missing anything let me know lol
Im working on posting pics. Its saying mine are to large.
Share this post
Link to post
Sent from my LM-Q710(FGN) using Tapatalk
Share this post
Link to post
Not too bad for 400$ if frame is straight and clean.
Keep eye on swap shop and banshee Facebook for stuff you need.
Share this post
Link to post
Not bad. Problem is pipes and engines are so expensive anymore. But for $400 that's a good price.
Share this post
Link to post
I Picked one up kinda the same way for 700 but came with the motor
. Is it a deal? idk , depend how much you spend on parts really
The motor can go for a arm and a leg but it’s a banshee .
. I go on eBay and Facebook for parts .
Share this post
Link to post
id say no its not worth it. you can buy one already running for 2500 or less. your going to spend around 1200 on a good running motor shipped if your lucky and probably another 400 for pipes if you get something decent.  all the other stuff will add up to atleast 2500 in my opinion.  not trying to be a downer, ground up builds are expensive.
  • Like 1
Share this post
Link to post
Thanks everybody for your opinions on this. I found a complete running motor on Craigslist for $750. The frame and a arms are good. Front Shocks look a little rough. Trying to remove the axle and swinger. Got everything off the axle just to find out the axle is stuck in the carrier. So i removed the Carrier and axle from the swinger. The swinger bolt is also stuck so im thinking ill just cut the bolt on both sides to remove the swinger. Replace the bolt and be done with it.
Share this post
Link to post
Plenty of threads that have detailed info and pics on what can be removed and gusset info.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
