Sign in to follow this
Schweet97Z
Factory Decal Installation
I have some factory decals coming for my LE bike. I’ve seen many different techniques to applying decals. I’d like be able to use water with some dish soap to be able to move them around and squeegee the water out once I have them where I like them. My question is doing it that way will I ruin the glue or am I OK doing that with factory Yamaha decals?
Share this post
Link to post
There is a 3M spray. For the life of I can't remember name of it though. works on same principal as water and dish soap but dies not effect the decal glue.
Sent from my LG-H831 using Tapatalk
Share this post
Link to post
I’m not having any luck finding anything on 3m’s website regarding decal wet application. If the name comes back to you, please let me know.
Share this post
Link to post
I've applied decals with and without the soapy water method.  I've found that with the water method, the decals tend to come loose or curl up around the edges over time.  I think some of it depends on the decal.  The thicker the decal, the worse it is about turning loose at the edges.  I prefer the thinner decals like OEM.  Good luck.
Share this post
Link to post
I stumbled across a product called rapid tac. I think I’ll try that product
Share this post
Link to post
3M stuff no longer available due to carcinogenic properties. Was used for aviation decals. Which decals are you replacing.
Share this post
Link to post
Putting in the original rear fenders front fenders and side of front fenders
Share this post
Link to post
I used a product called miter bond. Just like crazy glue but with a spay that instantly cures the glue. You don't need much just in the edge if decal is starting to peel. Tape every thing off and good to go. Will make your eyes burn and water if in a small area.
Share this post
Link to post
Any ideas on good product to re-apply graphics that are rolling and peeling?
I’m obviously no expert, but maybe this would work.
3M 77 Super Multipurpose Adhesive Aerosol, Clear 16.75 Oz. Aerosol Can https://www.amazon.com/dp/B0000AZ735/ref=cm_sw_r_cp_api_lMXNAbWVHF9TS
Share this post
Link to post
What I like about that product is it says it doesn’t seep into the product and doesn’t yellow over time if any of your decals are clear.
Share this post
Link to post
I use Rapid Tac and has always worked well. Never tried it on OEM graphics but I'm sure you'll be fine. As far as the 3M 77 to keep down peeling graphics, I've tried and never had any success.
Share this post
Link to post
Cool thanks for the info!
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
