Having the Center clutch adjustment backing out on me 2nd time
Everythings been great for 20 hours on the banshee     , First time clutch lever went completely out on a pass .... i opend it up and found the adjustment screw like this ...
12573039_1676063349342413_47720216293767
.......          Found a washer and another nut in the clutch cover crannies  ....... I put the washer on , adjusted it normally , put the outer nut on ... tightend it , closed motor .........          Everything worked better then before ,     4 passes later ..... back to same problem.......       going to get the pancake bearing now , but is there anything else i should look for causing this ?  do i need to locktight the outer nut from coming out of adjustment  ?    welded ball ?        Do the pancake bearings require the ball ?
